0013075 | ParaView | (No Category) | public | 2012-04-10 14:55 | 2016-08-12 09:59 | ||||
Reporter | Danielle Pace | ||||||||
Product Version | 3.14 | ||||||||
Summary | 0013075: Change display properties of multiple images simultaneously | ||||||||
Description | It would be very helpful to be able to select multiple objects in the pipeline browser and change their display properties simultaneously. E.g. select two images, change representation to Slice, change slice #, and set to visible, and have it apply to both of the images. Right now, if this workflow is followed only one of the images has the display properties changed. | ||||||||
Project | Kitware | ||||||||
Type | feature | ||||||||
(0038185) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-04-10 14:55 | Danielle Pace | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038185 | |
