0013084 | ParaView | (No Category) | public | 2012-04-12 16:11 | 2016-08-12 09:59 | ||||
Reporter | Leo Liu | ||||||||
Assigned To | George Zagaris | ||||||||
Summary | 0013084: AMR Enzo Reader does not work with save /load state | ||||||||
Description | - Open VTKData/Data/AMR/Enzo/DD0010/moving7_0010.hierarchy - Check x-velocity, y-velocity and z-velocity and click Apply - Save state - Disconnect and Load state again. Notice that no data gets loaded. After hitting apply, still no data. | ||||||||
Project | TBD | ||||||||
(0028540) George Zagaris (developer) 2012-04-29 19:13 |
This happens b/c SetFileName() is called after the SetCellArrayStatus sequence. SetFileName initializes all the arrays to be disabled and hence no data is loaded. There are two approaches to fix this: (1) Remove the initialization from SetFileName that disables all the arrays. This is probably the easiest way to fix it, but, it will mean that by default all data will be loaded. (2) Change the call sequence, s.t., SetFileName() is called first and all other properties later. |
(0038186) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-04-12 16:11 | Leo Liu | New Issue | |
2012-04-12 16:11 | Leo Liu | Assigned To | => George Zagaris |
2012-04-29 19:13 | George Zagaris | Note Added: 0028540 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038186 | |
