0013129 | ParaView | (No Category) | public | 2012-04-25 06:38 | 2016-08-12 09:59 | ||||
Reporter | Benjamin Kaufner | ||||||||
Assigned To | Cory Quammen | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013129: Chart Axes setting is not reproduced after saving state file and reloading it | ||||||||
Description | If the Chart Axes property of a Line Series is set to Bottom-Right, the plot will have only default (bottom and left) chart axes again after state was saved and reloaded again. | ||||||||
Project | TBD | ||||||||
(0036659) Cory Quammen (developer) 2016-08-02 10:13 |
Seems to work now. Tested ParaView 5.1, Mac OS X, built-in server Launch ParaView Add Sphere Source Filters -> Scatter Plot Under Series Parameters, check the Normals_X variable and no others. Select the Normals_X variable Set the Chart Axes settings to Bottom-Right. Note the axis that appears on the right side. Save state file. Reset ParaView Load state file. The axes on the right side appears after loading the state file. |
(0038203) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-04-25 06:38 | Benjamin Kaufner | New Issue | |
2016-08-02 10:13 | Cory Quammen | Note Added: 0036659 | |
2016-08-02 10:13 | Cory Quammen | Status | backlog => customer review |
2016-08-02 10:13 | Cory Quammen | Resolution | open => fixed |
2016-08-02 10:13 | Cory Quammen | Assigned To | => Cory Quammen |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038203 | |
2016-08-12 09:59 | Kitware Robot | Status | customer review => closed |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
