0013185 | ParaView | (No Category) | public | 2012-05-17 04:03 | 2016-08-12 09:59 | ||||
Reporter | Carlos Tripiana Montes | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 3.14.1 | ||||||||
Summary | 0013185: EnSight file reader (*.case) doesn't work properly in parallel | ||||||||
Description | Hi all, As you can see in the image I've attached, when I loaded my EnSight file using standalone ParaView, it worked. Using paraview + pvserver (MPI) it didn't work. It seems EnSight Reader has some problem when Paraview runs parallel. Any ideas to solve this problem? Actually, that error is blocking my work now... Hope somebody can help me. Thanks in advance. | ||||||||
Project | TBD | ||||||||
Attached Files | error.png [^] (1,670,906 bytes) 2012-05-17 04:03 | ||||||||
(0038214) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-05-17 04:03 | Carlos Tripiana Montes | New Issue | |
2012-05-17 04:03 | Carlos Tripiana Montes | File Added: error.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038214 | |
