0013228 | ParaView | (No Category) | public | 2012-06-07 18:15 | 2016-08-12 09:59 | ||||
Reporter | ThomasF | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013228: Selecting Points with "Select Points On" from vtkUnstructuredGrid consisting of vtkQuadraticTetra doesn't work | ||||||||
Description | Selecting Points with "Select Points On" from vtkUnstructuredGrid consisting of vtkQuadraticTetra results in the following error: ERROR: In /Source/ParaView/release/ParaView/ParaViewCore/VTKExtensions/vtkSelectionConverter.cxx, line 224 vtkSelectionConverter (0x118681b70): Could not locate the original ids arrays. Did the geometry not produce them? | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038225) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-06-07 18:15 | ThomasF | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038225 | |
