0013238 | ParaView | (No Category) | public | 2012-06-13 09:57 | 2016-08-12 09:59 | ||||
Reporter | Gena Bug | ||||||||
Product Version | 3.14.1 | ||||||||
Summary | 0013238: Problem with 1D plotting on pyramidal mesh | ||||||||
Description | Hi! I've noticed a bug in the last version of Paraview (3.14.1) on Debian testing amd64. Plot over line in pyramidal mesh doesn't show me the curves (I've checked versions 3.8 and 3.12 -- they're both worked as expected). I attached an example file. It's a simple pyramidal mesh in a flat quadratic region. Try to create a 1D plot over X-axis ({0.0,3.0}, 1.5, 0.0) and you will see the problem. -----|- Gena. | ||||||||
Project | ParaViewVR | ||||||||
Attached Files | heat-wave.t_1.r_0.p_0.vtu [^] (37,629 bytes) 2012-06-13 09:57 | ||||||||
(0038228) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-06-13 09:57 | Gena Bug | New Issue | |
2012-06-13 09:57 | Gena Bug | File Added: heat-wave.t_1.r_0.p_0.vtu | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038228 | |
