0013258 | ParaView | (No Category) | public | 2012-06-21 13:22 | 2012-10-29 17:04 | ||||
Product Version | 3.14 | ||||||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013258: Calculator can't use tensor components correctly | ||||||||
Description | When I try to use the calculator for tensor components, I get an error message and no result. Formulas is as simple as follows: Ucg_XX This is with Auto Convert Properties turned on. ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1480 vtkFunctionParser (0CE42638): Syntax error: operator expected; see position 5 ERROR: In ..\..\..\..\src\ParaView3\VTK\Common\vtkFunctionParser.cxx, line 1480 vtkFunctionParser (0CE42638): Syntax error: operator expected; see position 5 Warning: In ..\..\..\..\src\ParaView3\VTK\Graphics\vtkArrayCalculator.cxx, line 401 vtkPVArrayCalculator (0C40FE58): An error occured when parsing the calculator's function. See previous errors. I am working on getting a dataset. | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0028716) Alan Scott (manager) 2012-06-21 14:49 |
Dataset given to Utkarsh, fbg_test.tgz. |
(0029194) Utkarsh Ayachit (administrator) 2012-09-12 16:09 |
Dataset lost. Requesting re-upload from Alan. |
(0029266) Utkarsh Ayachit (administrator) 2012-09-24 14:53 |
verified that this works. I remember fixing a tensor names related issue a while ago. That must have fixed this bug. |
(0029294) Utkarsh Ayachit (administrator) 2012-09-28 14:28 |
merged into master, if applicable. |
(0029361) Alan Scott (manager) 2012-10-10 21:51 |
Works! Tested Linux, remote server, master. |
2012-06-21 13:22 | Alan Scott | New Issue | |
2012-06-21 14:48 | Alan Scott | Summary | Calculator can't use tenros components. => Calculator can't use tensor components correctly |
2012-06-21 14:49 | Alan Scott | Note Added: 0028716 | |
2012-06-21 15:04 | Utkarsh Ayachit | Status | backlog => todo |
2012-06-21 15:04 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-06-21 15:04 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-08-14 09:30 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Kyle Lutz |
2012-09-12 16:09 | Utkarsh Ayachit | Note Added: 0029194 | |
2012-09-24 14:53 | Utkarsh Ayachit | Note Added: 0029266 | |
2012-09-24 14:53 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-09-24 14:53 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-09-24 14:53 | Utkarsh Ayachit | Resolution | open => no change required |
2012-09-24 14:53 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2012-09-25 11:10 | Utkarsh Ayachit | Relationship added | has duplicate 0010800 |
2012-09-28 14:28 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2012-09-28 14:28 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-09-28 14:28 | Utkarsh Ayachit | Note Added: 0029294 | |
2012-10-10 21:51 | Alan Scott | Note Added: 0029361 | |
2012-10-10 21:51 | Alan Scott | Status | customer review => closed |
2012-10-29 17:04 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.0 |
