0013261 | ParaView | (No Category) | public | 2012-06-22 14:40 | 2016-08-12 09:59 | ||||
Reporter | Greg Weirs | ||||||||
Product Version | 3.14 | ||||||||
Summary | 0013261: Plot-over-line view controls are broken | ||||||||
Description | In the plot-over-line filter, the default behavior is to automatically rescale the y axis (axes) to the data for each time. However, the rescaling does not happen. If the user manipulates the view controls with set axis range, that doesn't work, but then going back to automatic scaling does work. It might require more clicking around than that. I have observed that sometimes the autoscaling is applied when I have set the axis range, and also that the fixed axis range is maintained when the automatic scaling is selected. Log scaling does not work in either case - when entered it appears that the upper and lower bounds are interpreted as log values, rather than absolute values, and the autoscaling also does not interpret the values correctly. | ||||||||
Project | Sandia | ||||||||
(0038231) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-06-22 14:40 | Greg Weirs | New Issue | |
2013-01-08 21:24 | Alan Scott | Project | TBD => Sandia |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038231 | |
