0013399 | ParaView | (No Category) | public | 2012-08-27 14:23 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0013399: create new domain to enable/disable GUI input properties based on the number of components in the selected input array | ||||||||
Description | There should be a domain that allows an input property in the GUI to be enabled/disabled based on the number of components in the selected input array. For example, the vtkGradientFilter has options to compute vorticity and Q criterion but the input array must have exactly 3 components in order to do this. It would be nice if there was an domain for these properties (ComputeVorticity, VorticityArrayName, ComputeQCriterion, and QCriterionArrayName) such that they would be enable or disabled in the GUI if the selected input array had 3 components or not, respectively. | ||||||||
Project | TBD | ||||||||
Type | usability | ||||||||
(0038252) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-08-27 14:23 | Andy Bauer | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038252 | |
