0013492 | ParaView | (No Category) | public | 2012-10-04 15:58 | 2013-01-30 10:41 | ||||
Target Version | 4.0 | Fixed in Version | 3.98.1 | ||||||
Summary | 0013492: Remove Material Volume Fraction code for CTH | ||||||||
Description | Please remove the code that specifically looks for Material Volume Fraction for CTH (flat and AMR). Allow the code to work on any and all variables. For instance, AMR Contour needs this correction. This is working around a change by the CTH folks, where they have changed the name from Material Volume Fraction to Volume fraction. | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0029322) Alan Scott (manager) 2012-10-04 16:06 |
Needed for 4.0 |
(0029513) Utkarsh Ayachit (administrator) 2012-10-25 11:07 |
Alan, do you have a sample dataset for this? I think this may be already working since the code doesn't seem to look for name, but data type. |
(0029915) Utkarsh Ayachit (administrator) 2012-12-19 14:01 |
Refer to BUG# 0013473. We fix this issue by fixing the code in the reader to detect volume fraction arrays. |
(0029923) Utkarsh Ayachit (administrator) 2012-12-21 11:21 |
merged into master, if applicable. |
(0030021) Alan Scott (manager) 2013-01-08 19:04 |
This bug should not be fixed (and wasn't). The correct way to fix it is as per bug 13473. That way compressing the volume fraction to a byte still works. |
2012-10-04 15:58 | Alan Scott | New Issue | |
2012-10-04 16:06 | Alan Scott | Note Added: 0029322 | |
2012-10-04 16:06 | Alan Scott | Assigned To | => Alan Scott |
2012-10-04 16:06 | Alan Scott | Status | backlog => todo |
2012-10-04 16:06 | Alan Scott | Relationship added | related to 0013473 |
2012-10-23 20:59 | Alan Scott | Assigned To | Alan Scott => |
2012-10-25 11:05 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-25 11:07 | Utkarsh Ayachit | Note Added: 0029513 | |
2012-12-19 14:01 | Utkarsh Ayachit | Note Added: 0029915 | |
2012-12-19 14:01 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-12-19 14:01 | Utkarsh Ayachit | Resolution | open => won't fix |
2012-12-19 14:01 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2012-12-21 11:20 | Utkarsh Ayachit | Fixed in Version | => git-master |
2012-12-21 11:21 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-12-21 11:21 | Utkarsh Ayachit | Note Added: 0029923 | |
2013-01-08 19:04 | Alan Scott | Note Added: 0030021 | |
2013-01-08 19:04 | Alan Scott | Status | customer review => closed |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
