0013493 | ParaView | (No Category) | public | 2012-10-04 16:04 | 2016-07-14 20:48 | ||||
Assigned To | David C. Lonie | ||||||||
Summary | 0013493: Add filter that calculates and resets min and max per frame | ||||||||
Description | We need to add a filter that calculated and resets the min and max values for a variable per frame. An example would be using can.exo, resetting Accl per frame. | ||||||||
Project | Sandia | ||||||||
(0032535) David C. Lonie (developer) 2014-03-26 14:47 |
Can you clarify what is meant by 'resetting' the values? And is 'frame' the same as a timestep? |
(0036505) Alan Scott (manager) 2016-07-14 20:48 |
This has been implemented. You set it with the Edit/ Settings/ General/ Clamp and Udate every timestep. |
2012-10-04 16:04 | Alan Scott | New Issue | |
2013-02-06 18:15 | Utkarsh Ayachit | Assigned To | => Nikhil Shetty |
2013-06-05 16:29 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2014-03-21 00:14 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
2014-03-26 14:47 | David C. Lonie | Note Added: 0032535 | |
2014-03-26 14:47 | David C. Lonie | Status | backlog => todo |
2016-07-14 20:48 | Alan Scott | Note Added: 0036505 | |
2016-07-14 20:48 | Alan Scott | Status | todo => closed |
2016-07-14 20:48 | Alan Scott | Resolution | open => fixed |
