0013516 | ParaView | (No Category) | public | 2012-10-12 09:54 | 2012-11-16 08:50 | ||||
Reporter | Sven Buijssen | ||||||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013516: [git/master] ParaView-Superbuild: Windows x64: build error when using Visual Studio 9 2008 | ||||||||
Description | Windows 7 x64 CMake 2.8.9, ParaView git/master cmake-gui # from cmake-2.8.9-win32-x86.exe binary release source code location: C:/ParaView/git/Source/SuperBuild build location: C:/ParaView/git/BuildSuperBuild generator for the project: Visual Studio 9 2008 Win64 - use default native compilers - Finish Change settings: CMAKE_CONFIGURATION_TYPES = Release QT_QMAKE_EXECUTABLE = c:/qt/qt-4.8.2-x64/bin/qmake.exe # stemming from http://code.google.com/p/qt-msvc-installer/ [^] using qt-win64-opensource-4.8.2-noqt3-vs2008.exe, qt-win64-opensource-4.8.2-noqt3-vs2008-1.bin, qt-win64-opensource-4.8.2-noqt3-vs2008-2.bin to install Qt BUILD_TESTING: off PARAVIEW_BUILD_CGNS: off PARAVIEW_BUILD_Silo: off Configure Configure Generate Open png.vcproj in MS Visual Studio 2008 Version 9.0.30729.1 SP. Solution Explorer - Mark "png" - Context menu - Build fails with 2>1>CMake Error at cmake_install.cmake:83 (FILE): 2>1> file INSTALL cannot find 2>1> "C:/ParaView/git/MiniSuperBuild/png-build/libpng-config". | ||||||||
Project | TBD | ||||||||
Attached Files | build.log.gz [^] (1,948 bytes) 2012-10-12 09:54 0001-COMP-Fixed-build-issue-with-MSVC9-2008.patch [^] (1,036 bytes) 2012-10-12 09:55 [Show Content] | ||||||||
(0029368) Sven Buijssen (reporter) 2012-10-12 09:55 |
Patching SuperBuild to use a newer libpng (as suggested on http://old.nabble.com/CMake-error-with-libpng-1.5.7-using-MSVC-td33202700.html [^]) resolves the issue. Patch attached. |
(0029732) Sven Buijssen (reporter) 2012-11-16 07:42 |
Issue obsolete since commit fb7aee5ad84eec2f763544e62ca05fd8a5be443d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Nov 7 15:51:40 2012 -0500 Remove old superbuild files from ParaView. These are now in a separate git repository. Refer to the Wiki pages for details: http://paraview.org/Wiki/ParaView/Superbuild [^] CMake code in separate SuperBuild repository does not require libpng any more when setting generator to Visual Studio 9 2008 Win64. |
2012-10-12 09:54 | Sven Buijssen | New Issue | |
2012-10-12 09:54 | Sven Buijssen | File Added: build.log.gz | |
2012-10-12 09:55 | Sven Buijssen | Note Added: 0029368 | |
2012-10-12 09:55 | Sven Buijssen | File Added: 0001-COMP-Fixed-build-issue-with-MSVC9-2008.patch | |
2012-10-18 14:05 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-11-16 07:25 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2012-11-16 07:42 | Sven Buijssen | Note Added: 0029732 | |
2012-11-16 08:50 | Utkarsh Ayachit | Status | backlog => closed |
2012-11-16 08:50 | Utkarsh Ayachit | Resolution | open => no change required |
2012-11-16 08:50 | Utkarsh Ayachit | Fixed in Version | => 3.98.0 |
