0013521 | ParaView | (No Category) | public | 2012-10-15 14:27 | 2015-01-11 08:32 | ||||
Reporter | Burlen | ||||||||
Product Version | git-next | ||||||||
Target Version | 4.0 | Fixed in Version | 3.98.0 | ||||||
Summary | 0013521: stream tracer point source reset | ||||||||
Description | When using the stream tracer, the point source is reset every time the object is deselected in the pipeline browser. to reproduce: load a vector dataset create stream tracer change point apply stream tracer select reader select stream tracer <-- point source is reset | ||||||||
Project | TBD | ||||||||
Topic Name | 13521_fix_streamtracer_panel | ||||||||
(0029463) Utkarsh Ayachit (administrator) 2012-10-21 11:38 |
The problem seems to be with the stream tracer using the old-style panel. It seems to me that the pqPropertiesPanel may be better off keeping any old-style panels alive till the end of the application (or until the corresponding proxy is deleted), otherwise, we could fix the stream tracer panel, but other user plugins etc. may start showing similar issues. |
(0029533) Utkarsh Ayachit (administrator) 2012-10-28 21:01 |
commit b0d14641389a0880ddec536e919a75d9944e15d3 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Oct 28 21:00:03 2012 -0400 BUG 0013521. Fixed StreamTracer panel. StreamTracer panel was resetting point source properties in constructor. That's wrong since it resets properties from state files as well. Fixed it. Change-Id: Id0f3f89bcfb124e614c0b3f3bdef5b8e3c63a1c3 |
(0029534) Utkarsh Ayachit (administrator) 2012-10-28 21:29 |
commit ae0d750df07c59ec436219a4e42e211ae88765d1 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Sun Oct 28 21:28:45 2012 -0400 Updating stream-tracer to use new style panels. Updating the panel visibility for various stream tracer properties as well. Change-Id: I7794c51edab1110b79487e69fa600382a89fbd74 |
(0029618) Utkarsh Ayachit (administrator) 2012-10-31 10:47 |
merged into master, if applicable. |
(0029634) Alan Scott (manager) 2012-10-31 19:59 |
Tested remote server, Linux, master. |
2012-10-15 14:27 | Burlen | New Issue | |
2012-10-18 14:05 | Utkarsh Ayachit | Target Version | => 4.0 |
2012-10-21 11:38 | Utkarsh Ayachit | Note Added: 0029463 | |
2012-10-21 11:39 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2012-10-23 16:01 | Kyle Lutz | Status | backlog => todo |
2012-10-28 21:01 | Utkarsh Ayachit | Topic Name | => 13521_fix_streamtracer_panel |
2012-10-28 21:01 | Utkarsh Ayachit | Note Added: 0029533 | |
2012-10-28 21:01 | Utkarsh Ayachit | Status | todo => gatekeeper review |
2012-10-28 21:01 | Utkarsh Ayachit | Fixed in Version | => git-next |
2012-10-28 21:01 | Utkarsh Ayachit | Resolution | open => fixed |
2012-10-28 21:01 | Utkarsh Ayachit | Assigned To | Kyle Lutz => Utkarsh Ayachit |
2012-10-28 21:29 | Utkarsh Ayachit | Note Added: 0029534 | |
2012-10-31 10:46 | Utkarsh Ayachit | Fixed in Version | git-next => 3.98.0 |
2012-10-31 10:47 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2012-10-31 10:47 | Utkarsh Ayachit | Note Added: 0029618 | |
2012-10-31 19:59 | Alan Scott | Note Added: 0029634 | |
2012-10-31 19:59 | Alan Scott | Status | customer review => closed |
2015-01-11 08:31 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master df284751 |
2015-01-11 08:32 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master b0d14641 |
