0013548 | ParaView | (No Category) | public | 2012-10-23 11:24 | 2016-08-12 09:59 | ||||
Reporter | Sebastien Jourdain | ||||||||
Summary | 0013548: Wrong CMake dependency in Test definition | ||||||||
Description | Both of those test are defined in the wrong CMake location as there condition is not properly set at the first pass. Plugins-ServerManagerPython pvcrs.UncertaintyRendering === ParaViewCore/ServerManager/Default/Testing/Python/CMakeLists.txt === if(PARAVIEW_BUILD_PLUGIN_SurfaceLIC AND PARAVIEW_BUILD_PLUGIN_SLACTools) list(APPEND PY_TESTS_NO_BASELINE Plugins) endif() === Plugins/UncertaintyRendering/Testing/CMakeLists.txt === if(PARAVIEW_CLIENT_RENDER_SERVER_TESTS) add_client_render_server_tests("pvcrs" BASELINE_DIR ${PARAVIEW_DATA_ROOT}/Baseline TEST_SCRIPTS ${UNCERTAINTY_RENDERING_TESTS} ) endif() | ||||||||
Project | TBD | ||||||||
(0038259) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-10-23 11:24 | Sebastien Jourdain | New Issue | |
2012-10-23 11:24 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038259 | |
