0013557 | ParaView | (No Category) | public | 2012-10-24 06:13 | 2013-01-30 10:41 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | |||||||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013557: [git/master] VisItBridge GMVReader can trigger null pointer dereference in gmvread.c | ||||||||
Description | Unpack the attached "gmvfiles.zip". The files contained are derived from the sample ASCII GMV file "gmvtest.inp" that traditionally shipped with GMV binaries since at least February 2000. The only difference is that they use a "fromfile" for point and cell definitions. The two "fromfiles" have identical content, but different names and the directories where they are stored have a different recursion depth (both of which is crucial to trigger the issue). (Convert all 4 extracted files to carriage return-line feed endings if you are on Windows while issue 13553 is unresolved.) Download nightly build ParaViewSuperbuild. Load "file2load1st/gmvtest.inp.gmv" by means of the VisItBridge GMVReader. Apply. Delete. Load "../file2load2nd.gmv" by means of the VisItBridge GMVReader. => vtkVisItGMVReader will report "Unable to find any meshes" (which is bogus, because loading "file2load2nd.gmv" without having loaded "file2load1st/gmvtest.inp.gmv" first works fine) Delete. => ParaView will segfault because of an attempted null pointer dereference in gmvread_close() (gmvread.c:438). Patch attached. | ||||||||
Project | TBD | ||||||||
Attached Files | gmvfiles.zip [^] (2,137 bytes) 2012-10-24 06:13 0001-BUG-13557.-Fixed-segfault-in-gmvread.c.patch [^] (1,101 bytes) 2012-10-24 06:22 [Show Content] | ||||||||
(0029817) Sven Buijssen (reporter) 2012-11-30 13:53 |
commit db799d3eba9f6250fae0b244851a1cd58c5a497f Author: Sven Buijssen <sven.buijssen@tu-dortmund.de> Date: Wed Oct 24 11:50:34 2012 +0200 BUG 0013557. Fixed segfault in gmvread.c Correctly null terminate input directory string, especially when it has been set to a longer string previously. |
2012-10-24 06:13 | Sven Buijssen | New Issue | |
2012-10-24 06:13 | Sven Buijssen | File Added: gmvfiles.zip | |
2012-10-24 06:22 | Sven Buijssen | File Added: 0001-BUG-13557.-Fixed-segfault-in-gmvread.c.patch | |
2012-11-30 13:53 | Sven Buijssen | Note Added: 0029817 | |
2012-11-30 13:53 | Sven Buijssen | Status | backlog => closed |
2012-11-30 13:53 | Sven Buijssen | Resolution | open => fixed |
2012-11-30 13:53 | Sven Buijssen | Fixed in Version | => git-master |
2013-01-30 10:41 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
