0013600 | ParaView | (No Category) | public | 2012-11-05 09:41 | 2016-08-12 09:59 | ||||
Reporter | Sebastien Jourdain | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Summary | 0013600: Multi-block CSV writer does not work | ||||||||
Description | Open 2 csv files (or more) Group them to form a new multi-block The try to save that multi-block.... | ||||||||
Project | TBD | ||||||||
(0029729) Sebastien Jourdain (manager) 2012-11-15 16:34 |
This can not be solved easily as saving a multiblock rely on XML vtk writers and there is no vtkTable writer in XML, therefore that type of block is not supported as type of block to be written on the disk. |
(0038270) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-11-05 09:41 | Sebastien Jourdain | New Issue | |
2012-11-05 09:41 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2012-11-15 16:14 | Sebastien Jourdain | Assigned To | Utkarsh Ayachit => Sebastien Jourdain |
2012-11-15 16:14 | Sebastien Jourdain | Status | backlog => todo |
2012-11-15 16:14 | Sebastien Jourdain | Status | todo => active development |
2012-11-15 16:33 | Sebastien Jourdain | Status | active development => todo |
2012-11-15 16:34 | Sebastien Jourdain | Note Added: 0029729 | |
2012-11-15 16:34 | Sebastien Jourdain | Status | todo => backlog |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038270 | |
