View Issue Details [ Jump to Notes ] | [ Print ] |
0013680 | ParaView | (No Category) | public | 2012-11-27 08:02 | 2016-08-24 08:25 |
Reporter | Nikolaj Foged | |
Assigned To | Kitware Robot | |
Status | closed | Resolution | moved | |
Product Version | 3.14 | |
Target Version | | Fixed in Version | | |
Summary | 0013680: data arrys are changing when using the clip options |
Description | Paraview version 3.98 (also in 3.14)
When I make at clip in (borehole_round.vtk) the surface values that are potted change. I am 100% sure that I am using the same colorscale.
Note that the data range for the data arrays in the clipped layer goes from -3.03585e-38 to 1.21784e+33 while the data range is normal (and correct) in the non clipped layer.
Best regards
Nikolaj |
Tags | No tags attached. |
Project | ParaViewVR |
Topic Name | |
Type | incorrect functionality |
Attached Files | borehole_round.vtk [^] (2,734,804 bytes) 2012-11-27 08:02 |
