View Issue Details [ Jump to Notes ] | [ Print ] |
0013718 | ParaView | (No Category) | public | 2012-12-10 16:52 | 2016-08-12 09:59 |
Reporter | David Thompson | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | moved | |
Product Version | git-master | |
Target Version | | Fixed in Version | | |
Summary | 0013718: Selection inspector: deslecting last block has no effect. |
Description | When editing a block selection, unchecking a block which happens to be the only one selected does not empty the selection.
To reproduce (on Mac OS X, with PARAVIEW_DATA_ROOT set) using the attached script:
QT_MAC_NO_NATIVE_MENUBAR=1 ./bin/paraview.app/Contents/MacOS/paraview -dr --disable-light-kit --test-script=BadBlockDeselection.xml
You should be left with a block of can.ex2 highlighted but no blocks checked in the selection inspector. |
Tags | No tags attached. |
Project | TBD |
Topic Name | |
Type | incorrect functionality |
Attached Files | BadBlockDeselection.xml [^] (2,443 bytes) 2012-12-10 16:52 |
