0013722ParaView(No Category)public2012-12-11 14:542016-08-12 09:59
ReporterDavid Thompson
Assigned ToUtkarsh Ayachit
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0013722: Find Data "is one of" queries fail
DescriptionEither the Find Data dialog constructs a bad query or the query evaluation's Python implementation has a bug. Specifically, searching for cells where a variable obtains one of several values is broken.
To reproduce:
1. Open can.ex2.
2. Press Find Data toolbar button
3. Select "Find: Cell" as the field type.
4. Choose "Global ID" and "is one of" for the query clause. Enter "3000, 3050, 3150" in the clause's arguments.
5. Click "Run Query". You will receive the following error:
Traceback (most recent call last):
  File "<string>", line 5, in <module>
  File "...ParaView/trunk/lib/site-packages/paraview/extract_selection.py", line 147, in Exec
    ds = ExecData(self, iterCD.GetCurrentDataObject(), selection)
  File "...ParaView/trunk/lib/site-packages/paraview/extract_selection.py", line 122, in ExecData
    mask = eval(selection_node.GetQueryString(), globals(), new_locals)
  File "<string>", line 1, in <module>
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/lib/arraysetops.py", line 325, in in1d
    ar1, rev_idx = np.unique(ar1, return_inverse=True)
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/numpy/lib/arraysetops.py", line 179, in unique
    flag = np.concatenate(([True], aux[1:] != aux[:-1]))
ValueError: arrays must have same number of dimensions
TagsNo tags attached.
ProjectTBD
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0038296)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2012-12-11 14:54 David Thompson New Issue
2012-12-11 14:54 David Thompson Assigned To => Utkarsh Ayachit
2016-08-12 09:59 Kitware Robot Note Added: 0038296
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
