0013735 | ParaView | (No Category) | public | 2012-12-14 13:36 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0013735: the time information in the GUI information tab is incorrect for files with no points or cells | ||||||||
Description | When time stepping forward through a series of files, if one of the files doesn't have any points or cells the Filename, Current data time, Number of Cells, and Number of Points doesn't update properly. To reproduce the problem: 1) open up the time series slice..vtp (attached .vtp files in the tarball) -> appply 2) step to the second time step 3) look at the information tab and see that the Filename is slice1.vtp, the current data time is 0, the number of cells is 800 and the number of points is 441, even though it says in the upper right that the Time/time step is 1 (this is shown in badtimeinformation.png in the tarball). | ||||||||
Project | TBD | ||||||||
Attached Files | slice.tgz [^] (128,254 bytes) 2012-12-14 13:36 | ||||||||
(0030556) Andy Bauer (developer) 2013-04-12 10:36 |
Another possibly related issue is that the information tab isn't getting updated when time stepping through. Joe Insley noted that this only seems to happen when Cache Geometry is checked (the default value) under Animation settings. I was able to reproduce this with the can.ex2 sample data set and having Apply Displacements unchecked in the exodus reader. |
(0030557) Utkarsh Ayachit (administrator) 2013-04-12 12:02 |
The information tab is not updated by design when Cache Geometry is ON. There's no easy way of proving that information when caching geometry. |
(0038301) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-12-14 13:36 | Andy Bauer | New Issue | |
2012-12-14 13:36 | Andy Bauer | File Added: slice.tgz | |
2013-04-12 10:33 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2013-04-12 10:36 | Andy Bauer | Note Added: 0030556 | |
2013-04-12 12:02 | Utkarsh Ayachit | Note Added: 0030557 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038301 | |
