0013736 | ParaView | (No Category) | public | 2012-12-14 17:03 | 2013-01-09 16:50 | ||||
Reporter | Leo Liu | ||||||||
Assigned To | Leo Liu | ||||||||
Summary | 0013736: Add the ability to select cells crossing a contour value | ||||||||
Description | Given a contour value, we would like the ability to select all cells whose scalar ranges cross a contour value---equivalently, the cells containing the iso-surface. The proposed solution is to provide the functionality in the threshold filter. Currently, threshold filter has the ability to choose cells whose vertices fall in a threshold range. We will extend it---by providing a boolean option---so that it can choose cells whose scalar ranges are intersected by the threshold range. The user can then get the desired output by - Turning off the "AllScalars" option, which means that rather than requiring the entire cell scalar range to be contained in the threshold, only intersection is required - Turning on the "Use Continuous Cell Range Option", which means cells will be considered as continous intervals, rather than discrete set. - Setting the lower and upper threshold to be equal to the desired contour value | ||||||||
Project | TBD | ||||||||
Topic Name | 0013736_add_continuous_range_option_to_threshold_filter | ||||||||
Type | feature | ||||||||
(0029990) Utkarsh Ayachit (administrator) 2013-01-04 14:49 |
reopening since the said topic is not present on "stage" and hence not in "next" and hence cannot be merged into "master". |
(0029992) Leo Liu (reporter) 2013-01-04 16:45 |
Looks like this has already been merged into master. |
(0029993) Utkarsh Ayachit (administrator) 2013-01-07 09:54 |
Sounds good. Moving bug to "customer review". |
(0030050) Alan Scott (manager) 2013-01-09 16:50 |
Tested remote server, master, Linux. |
2012-12-14 17:03 | Leo Liu | New Issue | |
2012-12-14 17:03 | Leo Liu | Assigned To | => Leo Liu |
2012-12-26 10:46 | Leo Liu | Topic Name | => 0013736_add_continuous_range_option_to_threshold_filter |
2012-12-26 10:46 | Leo Liu | Status | backlog => gatekeeper review |
2012-12-26 10:46 | Leo Liu | Resolution | open => fixed |
2013-01-04 14:49 | Utkarsh Ayachit | Note Added: 0029990 | |
2013-01-04 14:49 | Utkarsh Ayachit | Status | gatekeeper review => backlog |
2013-01-04 14:49 | Utkarsh Ayachit | Resolution | fixed => reopened |
2013-01-04 16:45 | Leo Liu | Note Added: 0029992 | |
2013-01-07 09:54 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-01-07 09:54 | Utkarsh Ayachit | Resolution | reopened => fixed |
2013-01-07 09:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-07 09:54 | Utkarsh Ayachit | Note Added: 0029993 | |
2013-01-09 16:50 | Alan Scott | Note Added: 0030050 | |
2013-01-09 16:50 | Alan Scott | Status | customer review => closed |
