0013743 | ParaView | (No Category) | public | 2012-12-17 21:38 | 2016-08-12 09:59 | ||||
Product Version | 3.98.0 | ||||||||
Summary | 0013743: Add option for equal lighting from all angles | ||||||||
Description | We need to add a lighting mode that gives the user the same lighting from all angles. At the least, we need a slice to show the same no matter what side this of the slice is displayed. My user has particles radiating from a center point, hitting a discontinuous circular ribbon going around this center point at the top and the bottom. This user wants the top and bottom part of the ribbon to display the same colors. This can easily be seen as follows: * Sources/ Sphere. Apply. * Clip. Unselect "Show Plane". Apply. * Clip. Unselect "Show Plane". Select "Invert Selection". Apply. * Clip. Y axis. Origin 0.2. Unselect "Show Plane". Select "Invert Selection". Apply. * Clip. Y axis. Unselect "Show Plane". Apply. * We want the upper and lower strip to look the same. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0029902) Ken Moreland (manager) 2012-12-17 22:33 |
Are you sure this is what you want? "The same lighting from all angles" is the same thing as no lighting (or rather all ambient lighting). This would mean no shading whatsoever, which makes it rather impossible to determine spatial relationships. To get a feel of what this would look like, turn off all lighting. The geometry will look black. This request would just change black for some other uniform color. |
(0029940) Alan Scott (manager) 2012-12-21 13:47 |
Lets only implement this request when we have lighting per block, not lighting for the whole scene. |
(0038304) Kitware Robot (administrator) 2016-08-12 09:59 |
2012-12-17 21:38 | Alan Scott | New Issue | |
2012-12-17 22:33 | Ken Moreland | Note Added: 0029902 | |
2012-12-21 13:47 | Alan Scott | Note Added: 0029940 | |
2013-05-01 14:09 | Nikhil Shetty | Assigned To | => Nikhil Shetty |
2013-05-01 14:11 | Nikhil Shetty | Assigned To | Nikhil Shetty => |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038304 | |
