0013783ParaView(No Category)public2013-01-11 20:332016-08-12 09:59
ReporterAlan Scott
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Versiongit-master
Summary0013783: 2d x axis numbers cut off
DescriptionThe 2d text for the numbers down the X axis are one pixel too high, cutting them off. This is fairly hard to replicate. I suspect it happens with datasets that are very, very small. Here is how I replicated it.
Linux, local server, master.
Sources/ Wavelet. Apply.
Calculator. Formula == RTData*0.0001
Plot over line filter. X Axis Data = Use Data Array = Result (from calculator above). We are trying to make the X axis have very small numbers such as 0.006. Line Series should be only RTData. Apply.
The top pixel of some of the numbers down the X axis are cut off. They are one pixel higher than the ones that aren't cut off on top.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0036493)
Alan Scott (manager)
2016-07-14 18:34
This is still wrong in 5.1.1
(0038313)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2013-01-11 20:33 Alan Scott New Issue
2016-07-14 18:34 Alan Scott Note Added: 0036493
2016-08-12 09:59 Kitware Robot Note Added: 0038313
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
