0013793 | ParaView | (No Category) | public | 2013-01-15 13:52 | 2016-08-12 09:59 | ||||
Product Version | 3.98.0 | ||||||||
Summary | 0013793: Surface with Edges showing spurious edges. | ||||||||
Description | Load the attached "test.hyb.case" file and render in "Surface With Edges" mode. You'll see random lines as shown in pv3_98.png. The issue is not present when rendering as Surface or Wireframe or with ParaView 3.14. Utkarsh | ||||||||
Project | Kitware | ||||||||
Attached Files | testcase.zip [^] (3,498,078 bytes) 2013-01-15 13:52 pv3_98.png [^] (159,924 bytes) 2013-01-15 13:52 pv3_14.png [^] (150,000 bytes) 2013-01-15 13:53 | ||||||||
(0038315) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-15 13:52 | Utkarsh Ayachit | New Issue | |
2013-01-15 13:52 | Utkarsh Ayachit | File Added: testcase.zip | |
2013-01-15 13:52 | Utkarsh Ayachit | File Added: pv3_98.png | |
2013-01-15 13:53 | Utkarsh Ayachit | File Added: pv3_14.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038315 | |
