0013799 | ParaView | (No Category) | public | 2013-01-17 12:52 | 2015-01-11 08:28 | ||||
Target Version | Fixed in Version | 3.98.1 | |||||||
Summary | 0013799: Comparitive view doesn't show variables correctly. | ||||||||
Description | Linux, master, local server. Wavelet. Apply. Notice that the outline view is shown. Right click on the title bar for the 3d window. Convert to 3d View Comparative. Turn on visibility for Wavelet (this is a bug in another bug report). Change Representation to Surface. Try changing Solid Color to RTData. This variable doesn't show up. This is a bug. The way to show that it should is to split the screen, and display wavelet in a 3d window. If you then select the comparative view, RTData will show up as a color option. | ||||||||
Project | Sandia | ||||||||
Topic Name | 13799_comparative_view_fixes | ||||||||
Relationships | ||||||
(0030207) Utkarsh Ayachit (administrator) 2013-01-22 12:33 |
commit 87e901648e8eeed54573ba2a4e32b717ab0cfe0d Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jan 22 12:18:36 2013 -0500 Fixed Overlay mode in Comparative View. When in Overlay mode, all representations were simply showing the first timestep. This is because when the view was updated for (0, 0), it would update all representations in it, including those for other locations in the comparative grid. The caches for all those representations would be filled and subsequence updates would have no effect. This addresses that issue by clearing caches for representations at (i, j) location just before updating the representations at (i, j) location. Added a test for the same (ComparativeOverlay). Change-Id: I05493e4258e54a7dc9b4554c56f40f8271e22f21 commit 70f9e297b00ccb852dbb9bedaa65d3d83c9937fe Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Jan 22 11:57:59 2013 -0500 BUG 0013799. Variables not showing curretly for Comparative View. The problem was that the representations in each view were being updated using repr->Update() instead of simply letting the view update the representations as needed. Since vtkCompositeRepresentation::Update() no longer forwards the update request to internal representations, it meant that the UI ended up updating using old state of the representations -- hence the missing variables. This fixes that issue. Change-Id: Ia25e7dd8f4d5c0c368692894003567eb8bf79043 |
(0030257) Utkarsh Ayachit (administrator) 2013-01-26 10:27 |
SUMMARY --------------------------------------------- Topics merged into master: 0013365-huge-state-file (VTK) 0013470-CTH-AMR-OutlineFilter 13311_fix_time_marker 13784_cleanup_chart_settings_dialog 13799_comparative_view_fixes 13811_fix_3Dwidgets (VTK) 13817_fix_memory_issues 13818_fix_plot_min_max (VTK) 13821_fix_leaks_on_exit 13824_fix_calculator PvxFullScreenBorders vr-fixInteractors vr-missingIncludes |
(0030331) Alan Scott (manager) 2013-02-11 19:26 |
Tested 3.98.1, local server, Linux. |
2013-01-17 12:52 | Alan Scott | New Issue | |
2013-01-22 10:03 | Utkarsh Ayachit | Relationship added | related to 0013800 |
2013-01-22 11:57 | Utkarsh Ayachit | Relationship replaced | has duplicate 0013800 |
2013-01-22 12:00 | Utkarsh Ayachit | Topic Name | => 13799_comparative_view_fixes |
2013-01-22 12:33 | Utkarsh Ayachit | Note Added: 0030207 | |
2013-01-22 12:33 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-01-22 12:33 | Utkarsh Ayachit | Fixed in Version | => git-next |
2013-01-22 12:33 | Utkarsh Ayachit | Resolution | open => fixed |
2013-01-22 12:33 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-01-26 10:27 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2013-01-26 10:27 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-01-26 10:27 | Utkarsh Ayachit | Note Added: 0030257 | |
2013-01-30 10:40 | Utkarsh Ayachit | Fixed in Version | git-master => 3.98.1 |
2013-02-11 19:26 | Alan Scott | Note Added: 0030331 | |
2013-02-11 19:26 | Alan Scott | Status | customer review => closed |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 274e1691 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 8586b702 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 530dc146 |
2015-01-11 08:28 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 70f9e297 |
