0013812 | ParaView | (No Category) | public | 2013-01-22 17:00 | 2016-08-12 09:59 | ||||
Summary | 0013812: Comparative View - Overlay doesn't work correctly when animation time. | ||||||||
Description | Start a clean ParaView. * Load can.ex2, Apply * Close 3D view and create comparative view. * Turn on can's visibility. * From View menu, turn on "Comparative View Inspector" * Click "+" next to time to add a default time animation -- the view should update. Everything looks well. * Now check "Overlay all comparisons" -- observe the image (A) * Simply pick array to color by or just uncheck and check "Overlay" again. And look at the result (B) The data from time 0 is not show in (A) but shows up again in (B). That's a bug. | ||||||||
Project | TBD | ||||||||
(0030225) Utkarsh Ayachit (administrator) 2013-01-22 17:01 |
IF the time value for the first item is not 0, the problem doesn't arise. |
(0038317) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-22 17:00 | Utkarsh Ayachit | New Issue | |
2013-01-22 17:01 | Utkarsh Ayachit | Note Added: 0030225 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038317 | |
