0013828 | ParaView | (No Category) | public | 2013-01-29 04:40 | 2016-08-12 09:59 | ||||
Reporter | rwe | ||||||||
Product Version | 3.98.0 | ||||||||
Summary | 0013828: Build error due to missing header include | ||||||||
Description | During build I get the following error: [...]/src/Qt/Components/pqSILWidget.cxx: In member function ‘void pqSILWidget::toggleSelectedBlocks(bool)’: [...]/src/Qt/Components/pqSILWidget.cxx:193:3: error: ‘sort’ is not a member of ‘std’ This can be fixed by adding "#include <algorithm>" into the mentioned file. Compiler is: c++ (SUSE Linux) 4.5.1 20101208 [gcc-4_5-branch revision 167585] | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038321) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-29 04:40 | rwe | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038321 | |
