0013837 | ParaView | (No Category) | public | 2013-01-30 07:30 | 2016-08-12 09:59 | ||||
Reporter | John Biddiscombe | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0013837: disabling LOD rendering causes multiple warning and crashes | ||||||||
Description | If you turn off LOD rendering in the main options, then paraview has big trouble. the LOD actor is still "visible" even though it has a null input. This triggers many warning messages about ERROR: In ..\..\..\..\..\Code\ParaView\VTK\Common\ExecutionModel\vtkDemandDrivenPipeline.cxx, line 816 vtkCompositeDataPipeline (0000000009DC3B40): Input for connection index 0 on input port index 0 for algorithm vtkCompositePolyDataMapper2(000000001477 50B0) is of type vtkDataObject, but a vtkPolyData is required. and later crashes when GetBounds() is called on a null dataset. | ||||||||
Project | Release | ||||||||
Type | crash | ||||||||
(0030284) Utkarsh Ayachit (administrator) 2013-01-31 09:16 |
I cannot reproduce this. Can you elaborate please? What was the data source you created? |
(0038328) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-01-30 07:30 | John Biddiscombe | New Issue | |
2013-01-31 09:16 | Utkarsh Ayachit | Note Added: 0030284 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038328 | |
