0013869 | ParaView | (No Category) | public | 2013-02-11 16:00 | 2016-07-06 11:12 | ||||
Assigned To | Sean McBride | ||||||||
Target Version | Fixed in Version | git-master | |||||||
Summary | 0013869: Particle CoProcessing Adaptor doesn't build on OSX (Mountain Lion) | ||||||||
Description | Particle CoProcessing Adaptor doesn't build on OSX (Mountain Lion) Undefined symbols for architecture x86_64: "vtkCameraPass::New()", referenced from: vtkSmartPointer<vtkCameraPass>::New() in vtkParticlePipeline.cxx.o "vtkLightsPass::New()", referenced from: vtkSmartPointer<vtkLightsPass>::New() in vtkParticlePipeline.cxx.o "vtkOpaquePass::New()", referenced from: vtkSmartPointer<vtkOpaquePass>::New() in vtkParticlePipeline.cxx.o "vtkSequencePass::New()", referenced from: vtkSmartPointer<vtkSequencePass>::New() in vtkParticlePipeline.cxx.o "vtkOpenGLRenderer::SetPass(vtkRenderPass*)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkIceTCompositePass::SetRenderPass(vtkRenderPass*)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkIceTCompositePass::New()", referenced from: vtkSmartPointer<vtkIceTCompositePass>::New() in vtkParticlePipeline.cxx.o "vtkRenderPassCollection::New()", referenced from: vtkSmartPointer<vtkRenderPassCollection>::New() in vtkParticlePipeline.cxx.o "vtkRenderPassCollection::AddItem(vtkRenderPass*)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkIceTSynchronizedRenderers::New()", referenced from: vtkParticlePipeline::vtkParticlePipeline() in vtkParticlePipeline.cxx.o "vtkSynchronizedRenderWindows::SetIdentifier(unsigned int)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkSynchronizedRenderWindows::SetRenderWindow(vtkRenderWindow*)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkSynchronizedRenderWindows::SetParallelController(vtkMultiProcessController*)", referenced from: vtkParticlePipeline::SetupPipeline() in vtkParticlePipeline.cxx.o "vtkSynchronizedRenderWindows::New()", referenced from: vtkParticlePipeline::vtkParticlePipeline() in vtkParticlePipeline.cxx.o ld: symbol(s) not found for architecture x86_64 clang: error: linker command failed with exit code 1 (use -v to see invocation) make[2]: *** [lib/libvtkParticleAdaptor-pv3.98.1.dylib] Error 1 make[1]: *** [CoProcessing/Adaptors/ParticleAdaptor/CMakeFiles/ParticleAdaptor.dir/all] Error 2 | ||||||||
Tags | hackaton | ||||||||
Project | TBD | ||||||||
(0030342) Patrick O'Leary (manager) 2013-02-13 13:40 |
Particle CoProcessing Adaptor doesn't build on Fedora 18 x86_64 CMakeFiles/ParticleAdaptor.dir/vtkParticlePipeline.cxx.o: In function `vtkParticlePipeline::SetupPipeline()': vtkParticlePipeline.cxx:(.text+0xc86): undefined reference to `vtkRenderPassCollection::New()' vtkParticlePipeline.cxx:(.text+0xc9d): undefined reference to `vtkLightsPass::New()' vtkParticlePipeline.cxx:(.text+0xcbe): undefined reference to `vtkRenderPassCollection::AddItem(vtkRenderPass*)' vtkParticlePipeline.cxx:(.text+0xcc3): undefined reference to `vtkOpaquePass::New()' vtkParticlePipeline.cxx:(.text+0xce4): undefined reference to `vtkRenderPassCollection::AddItem(vtkRenderPass*)' vtkParticlePipeline.cxx:(.text+0xce9): undefined reference to `vtkSequencePass::New()' vtkParticlePipeline.cxx:(.text+0xd13): undefined reference to `vtkIceTCompositePass::New()' vtkParticlePipeline.cxx:(.text+0xd45): undefined reference to `vtkIceTCompositePass::SetRenderPass(vtkRenderPass*)' vtkParticlePipeline.cxx:(.text+0xd6d): undefined reference to `vtkCameraPass::New()' vtkParticlePipeline.cxx:(.text+0xdc8): undefined reference to `vtkOpenGLRenderer::SetPass(vtkRenderPass*)' vtkParticlePipeline.cxx:(.text+0xddb): undefined reference to `vtkSynchronizedRenderWindows::SetRenderWindow(vtkRenderWindow*)' vtkParticlePipeline.cxx:(.text+0xdea): undefined reference to `vtkSynchronizedRenderWindows::SetParallelController(vtkMultiProcessController*)' vtkParticlePipeline.cxx:(.text+0xdfb): undefined reference to `vtkSynchronizedRenderWindows::SetIdentifier(unsigned int)' CMakeFiles/ParticleAdaptor.dir/vtkParticlePipeline.cxx.o: In function `vtkParticlePipeline::vtkParticlePipeline()': vtkParticlePipeline.cxx:(.text+0x11b6): undefined reference to `vtkIceTSynchronizedRenderers::New()' vtkParticlePipeline.cxx:(.text+0x11c2): undefined reference to `vtkSynchronizedRenderWindows::New()' collect2: error: ld returned 1 exit status make[2]: *** [lib/libvtkParticleAdaptor-pv3.98.so.1] Error 1 make[1]: *** [CoProcessing/Adaptors/ParticleAdaptor/CMakeFiles/ParticleAdaptor.dir/all] Error 2 make: *** [all] Error 2 |
(0033407) Sean McBride (developer) 2014-10-01 20:24 |
Does this still repro? I don't recall seeing it on the dashboard of late... |
(0035362) Hyun Jae Kang (reporter) 2015-10-21 15:10 |
ITK had the similar linking error with XCode on Mac OS X 10.7. Please check the following page: http://review.source.kitware.com/#/c/20286/ [^] |
(0036175) Sean McBride (developer) 2016-07-06 11:11 |
I asked Utkarsh here at the hackathon, and he thinks this is no longer an issue. The referenced ITK issue is for ancient compilers (Apple's (GGC <=4.2 and LLVM-GCC <=4.2) or (Clang < 3.2)). The first 2 VTK doesn't even support anymore. |
2013-02-11 16:00 | Utkarsh Ayachit | New Issue | |
2013-02-13 13:40 | Patrick O'Leary | Note Added: 0030342 | |
2014-10-01 20:24 | Sean McBride | Note Added: 0033407 | |
2014-10-01 20:25 | Sean McBride | Tag Attached: hackaton | |
2015-10-21 15:10 | Hyun Jae Kang | Note Added: 0035362 | |
2016-07-06 11:10 | Sean McBride | Assigned To | => Sean McBride |
2016-07-06 11:11 | Sean McBride | Note Added: 0036175 | |
2016-07-06 11:12 | Utkarsh Ayachit | Status | backlog => closed |
2016-07-06 11:12 | Utkarsh Ayachit | Resolution | open => fixed |
2016-07-06 11:12 | Utkarsh Ayachit | Fixed in Version | => git-master |
