0013897 | ParaView | (No Category) | public | 2013-02-19 16:58 | 2016-07-14 18:46 | ||||
Assigned To | Alan Scott | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0013897: Add ability to clamp or threshold by time. | ||||||||
Description | I have a user that has multiple runs that overlap in time. He wants to use the first 3/4 of the first run, ignoring the rest of the time steps, and the last 3/4 of the second run. (These two runs do not represent exactly the same time - for instance the first dataset goes from time 0 to 4 seconds, and the second goes from 2 to 6 seconds. So, he wants 0-3 from the first dataset, and 3-6 seconds from the second dataset. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0036497) Alan Scott (manager) 2016-07-14 18:46 |
This can be done with an animation track, then turning on/off visibility. Another way to do it is to write out time frames from both, and using the images you want for your movie. Closing this bug. |
2013-02-19 16:58 | Alan Scott | New Issue | |
2016-07-14 18:46 | Alan Scott | Note Added: 0036497 | |
2016-07-14 18:46 | Alan Scott | Status | backlog => closed |
2016-07-14 18:46 | Alan Scott | Assigned To | => Alan Scott |
2016-07-14 18:46 | Alan Scott | Resolution | open => fixed |
