0013921 | ParaView | (No Category) | public | 2013-02-28 01:02 | 2013-05-18 20:00 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Product Version | 3.98.1 | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013921: 2d filters don't remember their setting. | ||||||||
Description | Some 2d filters are not remembering their settings as stuff is changed up-pipeline. This is extremely obnoxious, and this functionality really does make ParaView more useful. * Local server, Linux, 3.98.1. * Auto apply on. (not sure if it matters, but it shows the power of what I want to do.) * Open disk_out_ref.exo. All variables on. * Threshold. Temperature. Lower threshold 400. Upper threshold 800. * Plot over line. Turn all variables on, then off. Now, only plot temperature. Next, change the plot color (to Red, for instance), change the line type to dashed, and the marker to plus. (You do this by clicking on temp, highlighting this line). *Now, click on Threshold. Change the upper threshold as follows - exactly: place the curser to the right of the 8. Back space one. Hit the 7. You now have an upper threshold of 700. <<Bug>> And everything that you have painstakingly set on the line filter has gone away. Variable selections, colors, markers and line style. Further, if you go back to the Plot over Line filter (in the pipeline browser), and select temp (it was unselected by the action above), the Properties panel is very, very out of sync state wise with the 2d plot. | ||||||||
Project | Sandia | ||||||||
(0030396) Alan Scott (manager) 2013-02-28 01:04 |
This one is impacting Matt, thus marking it as todo. |
(0030636) Sebastien Jourdain (manager) 2013-04-30 15:33 edited on: 2013-04-30 15:34 |
This has been fixed after the panel clean up. The issue was related to the fact that the Apply was call too early hence the threshold output was empty which reset the plot over line filter + settings. |
(0030643) Alan Scott (manager) 2013-04-30 19:58 |
Most Excellent! Tested remote server, Linux, master. |
2013-02-28 01:02 | Alan Scott | New Issue | |
2013-02-28 01:04 | Alan Scott | Note Added: 0030396 | |
2013-02-28 01:04 | Alan Scott | Status | backlog => todo |
2013-04-30 15:33 | Sebastien Jourdain | Note Added: 0030636 | |
2013-04-30 15:33 | Sebastien Jourdain | Status | todo => gatekeeper review |
2013-04-30 15:33 | Sebastien Jourdain | Resolution | open => fixed |
2013-04-30 15:33 | Sebastien Jourdain | Assigned To | => Sebastien Jourdain |
2013-04-30 15:34 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2013-04-30 15:34 | Sebastien Jourdain | Note Edited: 0030636 | |
2013-04-30 19:58 | Alan Scott | Note Added: 0030643 | |
2013-04-30 19:58 | Alan Scott | Status | customer review => closed |
2013-04-30 19:58 | Alan Scott | Fixed in Version | => git-master |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
