0013924 | ParaView | (No Category) | public | 2013-03-03 16:15 | 2015-01-11 08:26 | ||||
Reporter | Sven Buijssen | ||||||||
Assigned To | Sebastien Jourdain | ||||||||
Product Version | 3.98.1 | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0013924: GMVReader plugin seals not watertight polyhedral cells on import | ||||||||
Description | The GMV file format allows for (nonstandard) cells to be described by their faces. One can define non-watertight cells this way. The attached sequence of GMV files stepwise defines a pyramid: the first file only contains the definition for the base, the second additionally defines one lateral face and so forth until the fifth file defines a watertight pyramid. The GMVReader plugin currently imports the first and the last file of said sequence correctly (as quad and pyramid, respectively). Unfortunately, the remaining files, all of which merely define a partial pyramid, are incorrectly imported as watertight pyramids, too (because they are incorrectly mapped to VTK_CONVEX_POINT_SET instead of the appropriate VTK_POLYHEDRON). | ||||||||
Project | TBD | ||||||||
Topic Name | gmv_reader_contribution | ||||||||
Attached Files | files13924.zip [^] (1,827 bytes) 2013-03-03 16:17 0001-BUG-13924-Fixed-import-issue-with-nonstandard-3D-cel.patch [^] (7,404 bytes) 2013-03-03 16:21 [Show Content] | ||||||||
(0030399) Sven Buijssen (reporter) 2013-03-03 16:21 |
Suggested patch attached |
(0030685) Utkarsh Ayachit (administrator) 2013-05-03 10:04 |
SUMMARY --------------------------------------------- Topics merged into master: 14040_add_save_animation_time_range gmv_reader_contribution pvw-add-jsduck-cmake-hints pvw-fix-lut-management-issue python_documentation_cleanup |
(0030698) Sven Buijssen (reporter) 2013-05-05 05:50 |
Fixed with suggested patch. |
2013-03-03 16:15 | Sven Buijssen | New Issue | |
2013-03-03 16:17 | Sven Buijssen | File Added: files13924.zip | |
2013-03-03 16:21 | Sven Buijssen | File Added: 0001-BUG-13924-Fixed-import-issue-with-nonstandard-3D-cel.patch | |
2013-03-03 16:21 | Sven Buijssen | Note Added: 0030399 | |
2013-03-03 22:47 | Sebastien Jourdain | Assigned To | => Utkarsh Ayachit |
2013-05-02 13:19 | Sebastien Jourdain | Topic Name | => gmv_reader_contribution |
2013-05-02 13:19 | Sebastien Jourdain | Status | backlog => gatekeeper review |
2013-05-02 13:19 | Sebastien Jourdain | Resolution | open => fixed |
2013-05-02 13:20 | Sebastien Jourdain | Assigned To | Utkarsh Ayachit => Sebastien Jourdain |
2013-05-03 10:04 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-05-03 10:04 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-03 10:04 | Utkarsh Ayachit | Note Added: 0030685 | |
2013-05-05 05:50 | Sven Buijssen | Note Added: 0030698 | |
2013-05-05 05:50 | Sven Buijssen | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2015-01-11 08:25 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master e6d9c084 |
2015-01-11 08:26 | Sebastiennn Jourdain | Source_changeset_attached | => ParaView master 842d1436 |
