0013941 | ParaView | (No Category) | public | 2013-03-14 05:51 | 2016-08-12 09:59 | ||||
Reporter | Sven Buijssen | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0013941: Find Data queries applied to time source yield syntax errors | ||||||||
Description | 3.98.0, 3.98.1 + git/master, Linux x86_64, builtin mode Sources - Time Source - Apply Edit - Find Data - Find Cell from TimeSource1 - Global ID is 0 - Run Selection Query => the following warning is raised: --------- Traceback (most recent call last): File "<string>", line 5, in <module> File "/ParaView-3.98.1-Linux-64bit/lib/paraview-3.98/site-packages/paraview/extract_selection.py", line 153, in Exec ds = ExecData(self, inputDO, selection) File "/ParaView-3.98.1-Linux-64bit/lib/paraview-3.98/site-packages/paraview/extract_selection.py", line 122, in ExecData mask = eval(selection_node.GetQueryString(), globals(), new_locals) File "<string>", line 1 Cell Label == 0 ^ SyntaxError: invalid syntax --------- A similar warning is raised for the queries: * "Cell Label is 0" * "Cell Value is 0" * "Cell X is 0.5" | ||||||||
Project | TBD | ||||||||
(0031802) Sven Buijssen (reporter) 2013-10-31 07:54 |
Issue still present after commit 9235a5e00149cf410a92da076d1749c283bc68af Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Wed Oct 23 10:29:47 2013 -0400 Refactor find-data dialog. |
(0038361) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-03-14 05:51 | Sven Buijssen | New Issue | |
2013-10-31 07:54 | Sven Buijssen | Note Added: 0031802 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038361 | |
