0014024 | ParaView | (No Category) | public | 2013-04-19 03:15 | 2016-08-12 09:59 | ||||
Reporter | kennyfujimoto | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0014024: Tab stop in "Sources/Text" does not Work | ||||||||
Description | When you insert a tab stop in the text field, the display window does not apply the tab stop. Also if you write in the python shell Text1.Text='Hi \t Tab \t stop' the \t is ignored. | ||||||||
Project | Kitware | ||||||||
(0038386) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-04-19 03:15 | kennyfujimoto | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038386 | |
