0014040 | ParaView | (No Category) | public | 2013-04-30 17:40 | 2013-05-18 20:00 | ||||
Assigned To | Sebastien Jourdain | ||||||||
Target Version | Fixed in Version | 4.0 | |||||||
Summary | 0014040: Save Animation should allow saving partial frames of movies | ||||||||
Description | A user should be able to save only a subset of the frames using Save Animation. This would be useful for very, very long movies where clusters timeout, or individual machines crash. For instance, if you have a dataset with 2000 frames, a user should be able to output frames 0 through 1000 in one run, then frames 1001 through 2000 in the next run. This is an important feature, and should be in 4.0 if possible. | ||||||||
Project | Sandia | ||||||||
Topic Name | 14040_add_save_animation_time_range_v2 | ||||||||
Type | feature | ||||||||
(0030641) Alan Scott (manager) 2013-04-30 17:40 |
For 4.0, if possible. |
(0030677) Sebastien Jourdain (manager) 2013-05-02 11:54 |
commit 141be5479f4416f472298eb176c3a14e3b5c604c Author: Sebastien Jourdain <sebastien.jourdain@kitware.com> Date: Thu May 2 11:22:45 2013 -0400 Allow animation writer to export only a subset of the available time range Change-Id: I9044102a35786a4dbae5482299b079b9b0d3138d |
(0030680) Utkarsh Ayachit (administrator) 2013-05-03 10:04 |
SUMMARY --------------------------------------------- Topics merged into master: 14040_add_save_animation_time_range gmv_reader_contribution pvw-add-jsduck-cmake-hints pvw-fix-lut-management-issue python_documentation_cleanup |
(0030711) Alan Scott (manager) 2013-05-07 17:06 |
I talked to Dave K, and we both agree - we would like the output file number to match the time step number. That way, a user can write numerous partial movies into the same directory, using the same file name, and not overwrite each other. |
(0030745) Utkarsh Ayachit (administrator) 2013-05-10 08:23 |
SUMMARY --------------------------------------------- Topics merged into master: 13853_catalyst_immediate_mode_rendering2 13981_fix_install_rules 13991_fix_window_sizes 14040_add_save_animation_time_range_v2 14046_fix_selection_issues 14058_fix_camera_animation_in_parallel_scale 14059-vtkPVGeometryFilter-unnecessary-array fix-custom-view-button-leak fix-multi-block-issues fix_pointsprite_plugin gmv-test-cleanup pvw-add-exit-button |
(0030765) Alan Scott (manager) 2013-05-14 20:20 |
Perfect. Thanks! Linux, remote server, master. |
2013-04-30 17:40 | Alan Scott | New Issue | |
2013-04-30 17:40 | Alan Scott | Summary | Save Animation should allow saving partial frames => Save Animation should allow saving partial frames of movies |
2013-04-30 17:40 | Alan Scott | Note Added: 0030641 | |
2013-04-30 17:40 | Alan Scott | Status | backlog => todo |
2013-05-01 12:00 | Utkarsh Ayachit | Assigned To | => Sebastien Jourdain |
2013-05-01 14:04 | Sebastien Jourdain | Status | todo => active development |
2013-05-02 11:54 | Sebastien Jourdain | Topic Name | => 14040_add_save_animation_time_range |
2013-05-02 11:54 | Sebastien Jourdain | Note Added: 0030677 | |
2013-05-02 11:54 | Sebastien Jourdain | Status | active development => gatekeeper review |
2013-05-02 11:54 | Sebastien Jourdain | Resolution | open => fixed |
2013-05-03 10:04 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-05-03 10:04 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-03 10:04 | Utkarsh Ayachit | Note Added: 0030680 | |
2013-05-07 17:06 | Alan Scott | Note Added: 0030711 | |
2013-05-07 17:06 | Alan Scott | Status | customer review => todo |
2013-05-08 15:20 | Sebastien Jourdain | Status | todo => active development |
2013-05-08 15:20 | Sebastien Jourdain | Topic Name | 14040_add_save_animation_time_range => 14040_add_save_animation_time_range_v2 |
2013-05-08 15:59 | Sebastien Jourdain | Status | active development => gatekeeper review |
2013-05-10 08:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-10 08:23 | Utkarsh Ayachit | Note Added: 0030745 | |
2013-05-14 20:20 | Alan Scott | Note Added: 0030765 | |
2013-05-14 20:20 | Alan Scott | Status | customer review => closed |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
