0014041 | ParaView | (No Category) | public | 2013-05-01 11:25 | 2016-08-12 09:59 | ||||
Assigned To | David C. Lonie | ||||||||
Summary | 0014041: Mulitblock Context menu doesn't respect *all* selected blocks | ||||||||
Description | * Open many.e * In 3D view, click "b" to enter block-selection mode and select a bunch of blocks by clicking-and-dragging. -- They get selected fine, even the Multiblock Inspector shows the block highlighted correctly. * Right-Click on the selected blocks in the 3D view -- Context menu shows up * Set Block Color -- it only changes the color for 1 block. That's incorrect. It should affect all selected blocks. | ||||||||
Project | Sandia | ||||||||
Topic Name | fix-multi-block-issues | ||||||||
(0030670) Utkarsh Ayachit (administrator) 2013-05-01 11:39 |
Same is true when you right-click and change attributed on the Multi-block instector panel with multiple elements selected. It must be noted that that seems to work fine for "Visibility" on the multi-block inspector, however. |
(0030731) Kyle Lutz (viewer) 2013-05-09 08:52 |
Merge topic 'fix-multi-block-issues' into next 11ee564 Fix bug when with 'Show Only Block' for multiple blocks 88aa079 Fix menu names in multi-block right-click menu d1a62c8 Only prompt once when setting multiple block opacities |
(0030750) Utkarsh Ayachit (administrator) 2013-05-10 08:23 |
SUMMARY --------------------------------------------- Topics merged into master: 13853_catalyst_immediate_mode_rendering2 13981_fix_install_rules 13991_fix_window_sizes 14040_add_save_animation_time_range_v2 14046_fix_selection_issues 14058_fix_camera_animation_in_parallel_scale 14059-vtkPVGeometryFilter-unnecessary-array fix-custom-view-button-leak fix-multi-block-issues fix_pointsprite_plugin gmv-test-cleanup pvw-add-exit-button |
(0031648) Alan Scott (manager) 2013-09-26 18:24 |
I tested this, and it didn't seem to work. I was using 8 servers. My rubber band select then color only what was selected only colored about 4 blocks, rather than the 50 I had selected. Don't close until this is resolved. |
(0031800) Alan Scott (manager) 2013-10-30 22:46 |
Isn't working. Changing to ToDo. |
(0038389) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-05-01 11:25 | Utkarsh Ayachit | New Issue | |
2013-05-01 11:25 | Utkarsh Ayachit | Assigned To | => Kyle Lutz |
2013-05-01 11:39 | Utkarsh Ayachit | Note Added: 0030670 | |
2013-05-08 12:53 | Kyle Lutz | Status | backlog => todo |
2013-05-08 12:53 | Kyle Lutz | Status | todo => active development |
2013-05-08 12:54 | Kyle Lutz | Topic Name | => fix-multi-block-issues |
2013-05-09 08:52 | Kyle Lutz | Note Added: 0030731 | |
2013-05-09 08:52 | Kyle Lutz | Status | active development => gatekeeper review |
2013-05-09 08:52 | Kyle Lutz | Resolution | open => fixed |
2013-05-10 08:23 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-05-10 08:23 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-05-10 08:23 | Utkarsh Ayachit | Note Added: 0030750 | |
2013-05-18 20:00 | Utkarsh Ayachit | Fixed in Version | git-master => 4.0 |
2013-09-26 18:24 | Alan Scott | Note Added: 0031648 | |
2013-10-30 22:46 | Alan Scott | Note Added: 0031800 | |
2013-10-30 22:46 | Alan Scott | Assigned To | Kyle Lutz => |
2013-10-30 22:46 | Alan Scott | Status | customer review => todo |
2014-02-19 14:09 | Utkarsh Ayachit | Assigned To | => David C. Lonie |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038389 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | 4.0 => |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
