0014084 | ParaView | (No Category) | public | 2013-05-23 10:41 | 2016-08-12 09:59 | ||||
Reporter | Jan Brezina | ||||||||
Product Version | 3.98.1 | ||||||||
Summary | 0014084: Inpractical rotation of 2d glyph triangle | ||||||||
Description | Also in 4.0 RC1 The 2d glyph 'triangle' is isosceles triangle pointing upwards by its smallest angle. The glyph arrow, however, points to the right. When using these two glyphs for visualisation of an vector field, the arrows correctly points to the direction of flow, but to use triangles I have to rotate them 270 degrees. | ||||||||
Project | TBD | ||||||||
(0038394) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-05-23 10:41 | Jan Brezina | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038394 | |
