0014087 | ParaView | (No Category) | public | 2013-05-23 12:07 | 2016-08-12 09:59 | ||||
Reporter | Jan Brezina | ||||||||
Product Version | 3.98.0 | ||||||||
Summary | 0014087: problems with SVG export | ||||||||
Description | Export to SVG is very useful since it can be further edited e.g. in Inscape. issues in version 4.0 RC1 (with default setting in export dialog): - Text of labels of bounding box axes is exported as a bunch of triangles unlike labels of the legend (color scale), which are exported as a text. - numbers of legend are covered by a rectangle consisting of two trinagles If the 3D view is not exported as raster image: - 'triangle' 2d glyphs is exported incomplete, only one side of every triangle appears in the SVG file Replication: - add a 2d glyph source - set triangle shape set visible bounding box axes - add mandelbrot source - set visible legend (color scale) set visible bounding box axes - export to SVG format once with and once without option "Rasterize 3D geometry" 2) Export to SVG format doesn't work in version 4.0 RC1 | ||||||||
Project | TBD | ||||||||
(0038395) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-05-23 12:07 | Jan Brezina | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038395 | |
