0014096 | ParaView | (No Category) | public | 2013-05-28 17:00 | 2016-08-12 09:59 | ||||
Reporter | Burlen | ||||||||
Summary | 0014096: non-printable characters sent or received with vtkErrorMacro | ||||||||
Description | in client server mode when server errors are reported in the terminal a number of non-printable chars are streamed out. This is usually an indication of reading uninitialized memory. To reproduce you need to generate a server side error, one way to do it is to trump up a "text.bov" file, the visit bridge will choke on it and report an error. pasting below (hope the non-printable chars come along for the ride): �t�� ERROR: In /scratch/01237/bloring/ParaView/next/ParaView/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 751 vtkPVCompositeDataPipeline (0x240ae70): Algorithm vtkVisItBOVReader(0x23f8e70) returned failure for request: vtkInformation (0x242ab30) Debug: Off Modified Time: 152125 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA_OBJECT ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 | ||||||||
Project | TBD | ||||||||
(0038398) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-05-28 17:00 | Burlen | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038398 | |
