View Issue Details [ Jump to Notes ] | [ Print ] |
0014113 | ParaView | (No Category) | public | 2013-06-04 15:46 | 2016-08-12 09:59 |
Reporter | Andy Bauer | |
Assigned To | Utkarsh Ayachit | |
Status | closed | Resolution | moved | |
Product Version | git-master | |
Target Version | | Fixed in Version | | |
Summary | 0014113: fix server side only reader plugins so that file extension hints are supported |
Description | For a server side only reader plugin (i.e. no GUI_RESOURCE_FILES set) the user should only have to load the plugin on the server (currently there's a warning triangle if this happens).
If I load the plugin on both the client and the server then when I try to read the file in it doesn't recognize the file extension. The attached file (nektarfiles.tgz) can be used to demonstrate the problem for the nektar reader plugin. |
Tags | No tags attached. |
Project | TBD |
Topic Name | |
Type | usability |
Attached Files | nektarfiles.tgz [^] (2,170 bytes) 2013-06-04 15:46 |
