0014153 | ParaView | (No Category) | public | 2013-06-28 09:55 | 2016-08-12 09:59 | ||||
Reporter | Felipe Bordeu | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014153: xdmf reader crash using stride | ||||||||
Description | a simple ascii xdmf file make the reader crash when playing with the stride parameter. to reproduce set Stride to 2 2 1 ----- file Structured_Ascci_2D.xdmf ---- <?xml version="1.0" ?> <!DOCTYPE Xdmf SYSTEM "Xdmf.dtd" []> <Xdmf Version="2.0" xmlns:xi="http://www.w3.org/2001/XInclude" [^] > <Domain Name="tests/Structured_Ascii.pxdmf"> <Grid Name="PGD1" > <Topology TopologyType="2DCORECTMESH" Dimensions="1 10 10" /> <Geometry GeometryType="ORIGIN_DXDYDZ"> <DataItem Name="Origin" Format="XML" NumberType="Float" Dimensions="3"> 0 0 0 </DataItem> <DataItem Name="Spacing" Format="XML" NumberType="Float" Dimensions="3"> 1 1 1 </DataItem> </Geometry> <Attribute Name="dep_x_0" Center="Node" AttributeType="Scalar" > <DataItem Format="XML" NumberType="Float" Precision="8" Dimensions="1 10 10"> 10 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4 1.5 1.6 1.7 1.8 1.9 2.0 2.1 2.2 2.3 2.4 2.5 2.6 2.7 2.8 2.9 3.0 3.1 3.2 3.3 3.4 3.5 3.6 3.7 3.8 3.9 4.0 4.1 4.2 4.3 4.4 4.5 4.6 4.7 4.8 4.9 5.0 5.1 5.2 5.3 5.4 5.5 5.6 5.7 5.8 5.9 6.0 6.1 6.2 6.3 6.4 6.5 6.6 6.7 6.8 6.9 7.0 7.1 7.2 7.3 7.4 7.5 7.6 7.7 7.8 7.9 8.0 8.1 8.1 8.3 8.4 8.5 8.6 8.6 8.8 8.9 9.0 9.1 9.1 9.3 9.4 9.5 9.6 9.6 9.8 9.9 0.0 </DataItem> </Attribute> </Grid> </Domain> </Xdmf> | ||||||||
Additional Information | for now the stride cant be tested with the new xdmf3. stride is not avilable for the moment. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038416) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-06-28 09:55 | Felipe Bordeu | New Issue | |
2014-08-26 04:04 | Felipe Bordeu | Description Updated | |
2014-08-26 04:04 | Felipe Bordeu | Additional Information Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038416 | |
