0014165 | ParaView | (No Category) | public | 2013-07-10 13:27 | 2016-08-12 09:59 | ||||
Reporter | Li-Ta Lo | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014165: Volume rendering crashes ParaView for "large" data set | ||||||||
Description | The binary distribution of ParaView 4.0.1 (Linux) downloaded from paraview.org has problem volume rendering vtkImage larger than certain size. To reproduce: 1. start paraview. 2. choose the Wavelet source. 3. set the extend to some "large" number like [-150, 150] for each dimension. 4. choose Volume as representation. 5. ParaView crashes with the following message: ERROR: In /home/utkarsh/Dashboards/MyTests/NightlyMaster/ParaViewSuperbuild-Release/paraview/src/paraview/VTK/Common/ExecutionModel/vtkAlgorithm.cxx, line 1387 vtkImageResample (0x42adb00): Attempt to get connection index 0 for input port 0, which has 0 connections. | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
(0038419) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-07-10 13:27 | Li-Ta Lo | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038419 | |
