0014171 | ParaView | (No Category) | public | 2013-07-15 09:48 | 2013-12-24 19:14 | ||||
Reporter | Zach Mullen | ||||||||
Assigned To | Scott Wittenburg | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014171: Provide sensible default camera manipulators in 2D interaction mode | ||||||||
Description | I'm creating a pvpython application with ParaViewWeb, and it requires the interaction mode to be 2D/parallel projection style. It was a bit confusing that ParaView provided some nice sensible default camera manipulators for 3D interaction mode, but none for 2D. I've attached a patch that provides the same 2D defaults that appear in the PV GUI application: left click to pan and right click to zoom. I think this is important for anyone creating pvpython apps that might want to use 2D interaction mode. | ||||||||
Project | TBD | ||||||||
Topic Name | add-zachs-sensible-default-2d-manipulators | ||||||||
Attached Files | default_2d_interactors.patch [^] (1,324 bytes) 2013-07-15 09:48 [Show Content] | ||||||||
(0031908) Scott Wittenburg (developer) 2013-12-06 11:52 |
Added Zach's patch for default camera manipulators in 2D interaction mode. |
(0031914) Sebastien Jourdain (manager) 2013-12-08 13:33 |
SUMMARY --------------------------------------------- Topics merged into master: (VTK) 14294-calculator-normals-tcoords add-zachs-sensible-default-2d-manipulators patch-mavericks (VTK) pvweb-test-images-to-dashboard --------------------------------------------- Topics reverted from next: implement_new_fragment_analysis sciberquest-test-timeout test_build_examples_against_pv_install unified-bindings2 |
(0032058) Alan Scott (manager) 2013-12-24 19:14 |
Trusting that Zach tested Scott's work, and Scott tested Zach's. Closing. |
2013-07-15 09:48 | Zach Mullen | New Issue | |
2013-07-15 09:48 | Zach Mullen | File Added: default_2d_interactors.patch | |
2013-12-06 11:52 | Scott Wittenburg | Topic Name | => add-zachs-sensible-default-2d-manipulators |
2013-12-06 11:52 | Scott Wittenburg | Note Added: 0031908 | |
2013-12-06 11:52 | Scott Wittenburg | Status | backlog => gatekeeper review |
2013-12-06 11:52 | Scott Wittenburg | Resolution | open => fixed |
2013-12-06 11:52 | Scott Wittenburg | Assigned To | => Scott Wittenburg |
2013-12-08 13:33 | Sebastien Jourdain | Status | gatekeeper review => customer review |
2013-12-08 13:33 | Sebastien Jourdain | Note Added: 0031914 | |
2013-12-24 19:14 | Alan Scott | Note Added: 0032058 | |
2013-12-24 19:14 | Alan Scott | Status | customer review => closed |
