0014175 | ParaView | (No Category) | public | 2013-07-17 15:41 | 2016-08-12 09:59 | ||||
Reporter | weirdtunguska | ||||||||
Product Version | 4.0 | ||||||||
Summary | 0014175: Paraview segfaults reading CSV file | ||||||||
Description | Hi all, Paraview segfaults with the following error: +++++++++++++++++++++++== ERROR: In /tmp/buildd/paraview-4.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x35257b0): Algorithm vtkMultiBlockPLOT3DReader(0x34ca6c0) returned failure for request: vtkInformation (0x34df5d0) Debug: Off Modified Time: 87656 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ERROR: In /tmp/buildd/paraview-4.0.1/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 754 vtkPVCompositeDataPipeline (0x35257b0): Algorithm vtkMultiBlockPLOT3DReader(0x34ca6c0) returned failure for request: vtkInformation (0x34df5d0) Debug: Off Modified Time: 87656 Reference Count: 1 Registered Events: (none) Request: REQUEST_INFORMATION ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 ERROR: In /tmp/buildd/paraview-4.0.1/VTK/Common/Core/vtkDataArrayTemplate.txx, line 146 vtkFloatArray (0x3a241b0): Unable to allocate 4907433984 elements of size 4 bytes. Qt has caught an exception thrown from an event handler. Throwing exceptions from an event handler is not supported in Qt. You must reimplement QApplication::notify() and catch all exceptions there. terminate called after throwing an instance of 'std::bad_alloc' what(): std::bad_alloc Abortado +++++++++++++++++++++++== when reading the following file: +++++++++++++++++++++++== x y z time in Toluene Persulfate SO4 BiomassSO4 pH cb TOTO TOTH 0 0 0 0.5 1 2.931676686546e-03 1.714238120643e+00 1.905562118513e-02 1.001186884638e-04 3.599160569709e+00 -1.433775305514e-04 5.550715995494e+01 1.110126959939e+02 0.00505051 0 0 0.5 1 2.217113245869e-03 2.350651746072e+00 2.426958753849e-02 1.000930166699e-04 3.512526069730e+00 -1.965321884669e-04 5.550741708266e+01 1.110127563211e+02 0.010101 0 0 0.5 1 1.584580533784e-03 2.976688708269e+00 2.704671483303e-02 1.000669529867e-04 3.504078293740e+00 -2.487165359197e-04 5.550754020319e+01 1.110127638217e+02 0.0151515 0 0 0.5 1 1.070734275932e-03 3.542716894750e+00 2.764725322787e-02 1.000447269695e-04 3.554340746720e+00 -2.958133273339e-04 5.550754443709e+01 1.110127278379e+02 0.020202 0 0 0.5 1 6.847514228604e-04 4.013745695099e+00 2.677235521767e-02 1.000277600303e-04 3.653729852433e+00 -3.349444186427e-04 5.550747118696e+01 1.110126672331e+02 0.0252525 0 0 0.5 1 4.149446950950e-04 4.375119861158e+00 2.521788414779e-02 1.000160372196e-04 3.796342696076e+00 -3.649271798144e-04 5.550736644171e+01 1.110126013489e+02 0.030303 0 0 0.5 1 2.385514148589e-04 4.631293492544e+00 2.360685872886e-02 1.000086629617e-04 3.977821016187e+00 -3.861597377860e-04 5.550726476302e+01 1.110125436916e+02 0.0353535 0 0 0.5 1 1.302759450707e-04 4.799575400769e+00 2.228394424112e-02 1.000044049312e-04 4.194487014374e+00 -4.000963633750e-04 5.550718395523e+01 1.110125002194e+02 0.040404 0 0 0.5 1 6.768412872331e-05 4.902382754856e+00 2.135063207479e-02 1.000021234543e-04 4.442996994496e+00 -4.086053498963e-04 5.550712802886e+01 1.110124710420e+02 0.0454545 0 0 0.5 1 3.351574924630e-05 4.961040021451e+00 2.076367625686e-02 1.000009769433e-04 4.720230318248e+00 -4.134579281314e-04 5.550709327278e+01 1.110124532580e+02 0.0505051 0 0 0.5 1 1.585227292111e-05 4.992442183763e+00 2.042734875728e-02 1.000004313317e-04 5.023241985739e+00 -4.160548318265e-04 5.550707350723e+01 1.110124432751e+02 0.0555556 0 0 0.5 1 7.179141765164e-06 5.008294000059e+00 2.024906482170e-02 1.000001843456e-04 5.349215335059e+00 -4.173653914872e-04 5.550706308161e+01 1.110124380584e+02 0.0606061 0 0 0.5 1 3.117533357673e-06 5.015876910245e+00 2.016074581471e-02 1.000000762132e-04 5.694535753915e+00 -4.179921854055e-04 5.550705793560e+01 1.110124355030e+02 0.0656566 0 0 0.5 1 1.302733700003e-06 5.019331036215e+00 2.011928852888e-02 1.000000309364e-04 6.054354563105e+00 -4.182776471924e-04 5.550705553164e+01 1.110124343235e+02 0.0707071 0 0 0.5 1 5.263105367051e-07 5.020836116228e+00 2.010071112589e-02 1.000000119402e-04 6.411492578046e+00 -4.184020114074e-04 5.550705446966e+01 1.110124338229e+02 0.0757576 0 0 0.5 1 2.060708971207e-07 5.021466067191e+00 2.009273933825e-02 1.000000044882e-04 6.707434342031e+00 -4.184540569239e-04 5.550705403605e+01 1.110124336491e+02 0.0808081 0 0 0.5 1 7.839072109788e-08 5.021720301604e+00 2.008944265613e-02 1.000000016462e-04 6.879251514360e+00 -4.184750589480e-04 5.550705387311e+01 1.110124336077e+02 0.0858586 0 0 0.5 1 2.903970012523e-08 5.021819573413e+00 2.008812998047e-02 1.000000005902e-04 6.954035867810e+00 -4.184832589057e-04 5.550705381323e+01 1.110124336005e+02 0.0909091 0 0 0.5 1 1.049836599831e-08 5.021857192384e+00 2.008762556978e-02 1.000000002072e-04 6.983129548243e+00 -4.184863660310e-04 5.550705379111e+01 1.110124335994e+02 +++++++++++++++++++++++== | ||||||||
Project | TBD | ||||||||
Type | crash | ||||||||
Attached Files | toluene.chem.xyz.tsv [^] (2,360,236 bytes) 2013-07-17 15:41 | ||||||||
(0031879) Utkarsh Ayachit (administrator) 2013-11-26 13:55 |
Tab-separated files are currently not supported. Replace all tabs to spaces or commas. |
(0038423) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-07-17 15:41 | weirdtunguska | New Issue | |
2013-07-17 15:41 | weirdtunguska | File Added: toluene.chem.xyz.tsv | |
2013-11-26 13:55 | Utkarsh Ayachit | Note Added: 0031879 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038423 | |
