0014189 | ParaView | (No Category) | public | 2013-07-25 15:43 | 2016-08-12 09:59 | ||||
Assigned To | David Thompson | ||||||||
Summary | 0014189: vtkScalarsToColors::SetAnnotations(...) does not update correctly. | ||||||||
Description | If vtkScalarsToColors::SetAnnotations(..,...) is called with certain arrays, and those array are later changed from code outside vtkScalarsToColors, vtkScalarsToColors never realizes the change. Calling SetAnnotations(..) again has no effect. e.g. vtkVariantArray* foo=... vtkStringArray* bar=... /// fill values stc->SetAnnotations(foo, bar); /// Render/Update the LUT. Annotations shown/used as expected /// change values in foo and bar stc->SetAnnnotations(foo, bar); /// Render/Update the LUT. Annotations won't be changed, it will still /// use the old values. DOing the following overcomes the issue: stc->SetAnnnotations(NULL, NULL); stc->SetAnnnotations(foo, bar); | ||||||||
Project | TBD | ||||||||
(0038426) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-07-25 15:43 | Utkarsh Ayachit | New Issue | |
2013-07-25 15:43 | Utkarsh Ayachit | Assigned To | => David Thompson |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038426 | |
