0014193 | ParaView | (No Category) | public | 2013-07-29 14:44 | 2013-10-24 15:22 | ||||
Assigned To | Ben Boeckel (Kitware) | ||||||||
Target Version | 4.1 | Fixed in Version | |||||||
Summary | 0014193: Catayst Essentials Edition missing implicit functions | ||||||||
Description | Catayst Essentials Edition is missing implicit functions. Since the edition includes "Clip" filter, it needs to have the implicit functions as well. To reproduce the problem using a Essentials-Python edition, try the following in pvpython: > from paraview.simple import * > Clip() You'll get errors about implicit functions. We should not be getting these errors. | ||||||||
Project | LANL-InSitu | ||||||||
(0031361) Utkarsh Ayachit (administrator) 2013-07-29 14:46 |
Same is true when one creates the "Glyph" filter. The following should not raise any errors on creation of the filters. > from paraview.simple import * > Calculator() > Contour() > Clip() > Slice() # Cut is called Slice > Glyph() |
(0031739) Ben Boeckel (Kitware) (developer) 2013-10-24 15:22 |
There is a test in Catalyst builds with Python for this which is merged into master: http://review.source.kitware.com/#/c/12008/5/Catalyst/Editions/Essentials/Testing/Essentials/use-essentials.py [^] |
2013-07-29 14:44 | Utkarsh Ayachit | New Issue | |
2013-07-29 14:44 | Utkarsh Ayachit | Assigned To | => Ben Boeckel (Kitware) |
2013-07-29 14:46 | Utkarsh Ayachit | Note Added: 0031361 | |
2013-10-22 12:56 | Utkarsh Ayachit | Target Version | => 4.1 |
2013-10-24 15:22 | Ben Boeckel (Kitware) | Note Added: 0031739 | |
2013-10-24 15:22 | Ben Boeckel (Kitware) | Status | backlog => closed |
2013-10-24 15:22 | Ben Boeckel (Kitware) | Resolution | open => fixed |
