0014217ParaView(No Category)public2013-08-09 18:142013-11-01 13:17
ReporterAlan Scott
Assigned ToUtkarsh Ayachit
PriorityhighSeverityminorReproducibilityhave not tried
StatusclosedResolutionno change required
PlatformOSOS Version
Product Versiongit-master
Target VersionFixed in Version4.1
Summary0014217: Color Map Editor - Opacity function doesn't allow tabs
DescriptionMarking high, since this is lost, important functionality.
Wavelet, Apply.
CleanToGrid, Apply.
Volume Render.
Now, open the Color Map Editor.
Click on the Opacity line, two places close together.
Since some users need numerous points virtually right on top of each other, you need to be able to select between them without using the mouse. Previously, we used the <tab> key, moving right with <tab> and left with <shift><tab> We need this functionality back.
TagsNo tags attached.
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
  Notes
(0031652)
2013-09-27 15:13
Alan,
The keys to use are the arrow keys. Left arrow and right arrow will help you move between the active control points. I verified that the keys are consistent with 4.0.1.
Also note that the mouse should be within the widget for the key events to be received by the widget, otherwise they are lost.
(0031653)
2013-09-27 15:13
feel free to reopen if needed.
(0031660)
2013-09-30 09:21
SUMMARY
Topics merged into master:
        0014284_fix_color_map
        13797_fix_chart_sizes
        14287_fix_proxy_delete
        14289_fix_extent_issues
        14299_fix_contour_panel
        14309-chart-selection-buggy
        fix_python_windows_coprocessing
(VTK) forward-to-vtk-master
(VTK) parallel-surface-lic-pv
        sqtk-fix-some-issues
(0031794)
Alan Scott (manager)
2013-10-30 22:36
Somewhat confusing at first, but I agree that this works. Closing.
 Issue History
2013-08-09 18:14 Alan Scott New Issue
2013-09-27 15:13 Utkarsh Ayachit Note Added: 0031652
2013-09-27 15:13 Utkarsh Ayachit Note Added: 0031653
2013-09-27 15:13 Utkarsh Ayachit Status backlog => gatekeeper review
2013-09-27 15:13 Utkarsh Ayachit Fixed in Version => git-master
2013-09-27 15:13 Utkarsh Ayachit Resolution open => no change required
2013-09-27 15:13 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2013-09-30 09:20 Utkarsh Ayachit Fixed in Version git-master => git-next
2013-09-30 09:21 Utkarsh Ayachit Status gatekeeper review => customer review
2013-09-30 09:21 Utkarsh Ayachit Note Added: 0031660
2013-10-21 08:16 Utkarsh Ayachit Fixed in Version git-next => git-master
2013-10-30 22:36 Alan Scott Note Added: 0031794
2013-10-30 22:36 Alan Scott Status customer review => closed
2013-11-01 13:17 Utkarsh Ayachit Fixed in Version git-master => 4.1
