0014227 | ParaView | (No Category) | public | 2013-08-13 19:01 | 2013-11-01 13:18 | ||||
Product Version | 4.0 | ||||||||
Target Version | 4.1 | Fixed in Version | 4.1 | ||||||
Summary | 0014227: Control points in transfer function editor not remembered correctly | ||||||||
Description | When you delete a control point from a transfer function and then close and reopen the transfer function editor, the control point seems to resurrect itself. To replicate, do the following. 1. Create a Wavelet source. 2. Volume Render RTData. 3. Open the Edit Color dialog box. 4. Turn on advanced controls (if necessary). 5. Add a control point (either color or transparency). Close the Edit Color dialog. 6. Open the Edit Color dialog. Delete the control point just created. 7. Close the Edit Color dialog. 8. Open the Edit Color dialog. The control point is mysteriously back. | ||||||||
Project | Sandia | ||||||||
(0031445) Utkarsh Ayachit (administrator) 2013-08-14 10:21 |
Ken, this doesn't seem to happen with the updated color editor. Can you try with git-master (instead of 4.0)? |
(0031447) Ken Moreland (manager) 2013-08-14 11:46 |
I cannot replicate this on the master branch. Looks fixed. |
2013-08-13 19:01 | Ken Moreland | New Issue | |
2013-08-13 19:01 | Ken Moreland | Target Version | => 4.1 |
2013-08-14 10:21 | Utkarsh Ayachit | Note Added: 0031445 | |
2013-08-14 10:21 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2013-08-14 10:21 | Utkarsh Ayachit | Fixed in Version | => git-master |
2013-08-14 10:21 | Utkarsh Ayachit | Resolution | open => no change required |
2013-08-14 10:21 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2013-08-14 10:22 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2013-08-14 11:46 | Ken Moreland | Note Added: 0031447 | |
2013-08-14 11:46 | Ken Moreland | Status | customer review => closed |
2013-11-01 13:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.1 |
