0014232 | ParaView | (No Category) | public | 2013-08-14 14:38 | 2016-08-12 09:59 | ||||
Summary | 0014232: Keyframe values displaying incorrectly in Animation View | ||||||||
Description | When you first create a track in the Animation View, the keyframe values at either end of the bar are not always set to the wrong value (although the actual internal value seems to work fine). To replicate: 1. Create a Sphere source. Apply. 2. Open the Animation View. 3. Create a track for Sphere1 - Start Theta Note at this point that the track created has a keyframe value of 0 on both sides of the bar even though it is supposed to have a value of 360 at the right end. If you hit play, you can see that the animation does indeed end with start theta at 360. Also, if you double-click that bar and observe each keyframe, they look correct. Interestingly, if you click OK on the keyframe editor, the bar gets corrected. | ||||||||
Project | TBD | ||||||||
(0038435) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-08-14 14:38 | Ken Moreland | New Issue | |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 221d7783 |
2015-01-11 08:23 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master dd5e0246 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038435 | |
