0014246 | ParaView | (No Category) | public | 2013-08-26 20:45 | 2016-08-12 09:59 | ||||
Assigned To | Sankhesh Jhaveri | ||||||||
Summary | 0014246: Measure distance between nodes | ||||||||
Description | We need a tool that will allow a user to measure the distance between two nodes. I have a ParaView user that uses EnSight when this functionality is needed. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
Relationships | ||||||
(0031498) Alan Scott (manager) 2013-08-26 20:47 |
Also, although the ruler will profice some of thus functionality, the ruler fails when the user wants to just type in global node ids. These may be inside of the object - i.e., not on the surface. |
(0038439) Kitware Robot (administrator) 2016-08-12 09:59 |
2013-08-26 20:45 | Alan Scott | New Issue | |
2013-08-26 20:47 | Alan Scott | Note Added: 0031498 | |
2013-08-26 21:49 | Alan Scott | Note Added: 0031499 | |
2013-08-26 21:50 | Alan Scott | Note Deleted: 0031499 | |
2014-02-13 14:05 | Utkarsh Ayachit | Assigned To | => Sankhesh Jhaveri |
2016-07-14 20:20 | Alan Scott | Relationship added | related to 0015228 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038439 | |
